Adjusting screw on carb
Randy
10-13-2002 19:43:36
Took carb off I.H. C-135 engine. Cleaned the carb from top to bottom, but cannot get the adjusting screw to turn, it seems to be rusted in place. Any suggestions on how to get it unstuck.
Thanks
Randy
Don LC
10-14-2002 07:10:11
 Re: Adjusting screw on carb in reply to Randy, 10-13-2002 19:43:36
First soak it with WD-40 every time you walk by it....find a good quality screw driver....use as big a screw driver that will fit....tap the screw driver with a small hammer...try turning the screw boh ways...more WD-40 ---more taps....more turning....do this until you have it loose.....good luck
