Steering wheel removal
300 Randy
11-07-2001 10:14:18
I was having trouble getting the steering wheel off of my 300u. I ended up using a brake drum puller, pulling on the plastic part of wheel and then heating the hub with a mapp gas tourch and it poped right off. Just thought I pass it along
Terry O
11-09-2001 08:19:29
 Re: Steering wheel removal in reply to 300 Randy, 11-07-2001 10:14:18
Do yourself a big favor before you put the steering wheel back on, put a lite coat of anti-sieze on the shaft, and in the steering wheel hub. It'll be SO much easier the next time you need to pull the wheel off. Trust me!
Terry O
Leon
11-21-2001 18:40:52
 Re: Re: Steering wheel removal in reply to Terry O, 11-09-2001 08:19:29
I used to back the nut out to where it was flush with the steering shaft and then rap it with a hammer, hitting the shaft and nut squarely. All this was done while putting pulling pressure on the wheel, usually with my knees under the steering wheel. Don't hit so hard as to damage the shaft or nut. If this don't work after a couple raps, go to plan B.
Pete Tatham
11-08-2001 01:21:00
I've shifted some really frozen steering wheels using a bearing puller and as Randy suggests, some heat. They really come off with a bang!
