Swing arm chain ford 4500 backhoe
baron
10-19-2002 12:33:47
Hello I broke the swing arm chain on the hoe. Any tips on how to fix is appreciated!!! Can the chain material be purchased separately to make the new chain or must a kit be purchases from Ford thank you baron
ray
01-04-2003 05:21:01
 Re: Swing arm chain ford 4500 backhoe in reply to baron, 10-19-2002 12:33:47
It is a two part chain. It separates at midpoint by removing a bolt that you can reach thru the main frame of the boom. You will have to remove the small rubber hose that connects the two swing cylinders. You can reach those under the seat. And,loosen the feed lines to the cylinders enough so you can pull them out when you hook it all up at the end. When you disconnect the linkage put a bar thru the cylinder shaft holes so they won't retract. If they do it will add to your work. They cost $300.00 ea. I couldn't attempt a repair given circumstances but I would now. Let me know if this helps.
