Cub cadet
jay
10-27-2002 22:19:08
how do I replace clutch disc on cub cadet model 122 and check an fill oil in rototiller model 1.
rhouston
10-30-2002 12:04:45
 Re: cub cadet in reply to jay, 10-27-2002 22:19:08
if it's anything like my 126 you have to split the tractor just like the big guys. not hard just seemed like a lot of work for a garden tractor. I had to work on creeper gear at same time so just the clutch may be different. have to remove seat and rear fenders. unbolt frame rails and pull tractor apart (Ie physicaly pull front and back away from each other) it was a few years ago and thats all i remember.
Don LC
10-31-2002 21:50:46
 Re: Re: cub cadet in reply to rhouston, 10-30-2002 12:04:45
I had a 126 and my dad had a 127....I removed the hood ,that is 2 bolts.....removed the castiron grill I think that was 2 or 3 on each side.....4 bolts in the bottom of the engine.....then just slide the engine forward about 3 or 4 inches.....take the old disk off the three pins ....put the new one on the three pins .....put her back togeather in reverse of the way you took it apart..... .If you work real slow it will take about 45 minutes to an hour....
