Coolant in carb. and on plugs
Cody
10-31-2002 10:42:55
i'm rebuilding an 8n and i have put in new pistons, rings, valves, gaskets, carb. kit, distributor kit. i try to start it, but it won't start. it turns over but won't fire. i noticed antifreeze coming from the air intake of the carb. and also some on the bottoms of the plugs. is that what is causing it not to start? also, i no longer am getting spark on the plugs. what would be causing this? thanks
cody
Dennis Benson
11-01-2002 19:15:42
 Re: coolant in carb. and on plugs in reply to Cody, 10-31-2002 10:42:55
That sounds like a leaking head gasket, or a crack in the block or head.
