1855 leaking
Tom Kelley
11-05-2002 08:46:59
My perfect 1855 seems to become less perfect everyday. At over 6000 hours she's a tight old girl with the exception of an oil leak around the PTO shaft bearing.
How can I repair this problem without replacing the whole casting? I have already tried a new bearing and it didn't make any difference whatsoever.
Jim in UK
11-11-2002 05:58:41
 Re: 1855 leaking in reply to Tom Kelley, 11-05-2002 08:46:59
I am not that familiar with the 1855, but have worked on a few tractors. Did you check the shaft to see if it is worn in the area of the seal? If it is, get a seal runner and slip it over the shaft then install the new seal. Good Luck and I hope that this helps.
John Frederick
11-18-2002 20:26:31
 Re: Re: 1855 leaking in reply to Jim in UK, 11-11-2002 05:58:41
Sometimes I use SealLube Seal Expander in hydraulic systems. It works well.
