NAA Points problem?
Gary Wilkerson
11-15-2002 08:06:38
My NAA has been giving problems with the points. I can crank the tractor without the Dist cap on to see if the points and coil are operational. What I see at the points is a pretty significant spark when they open and close. The reason I started to look at the points is over the last several months I 'd try to use the tractor and it would not start. I found that there was alot of carbon buildup, cleaning the points fixed it and trator was usable. I believe this excessive sparking is causing the carbon buildup. Is this normal? Could I have a defective points, condensor or coil?
Any help is appreciated!
Gary
Jim Spencer S.E. Michigan
12-01-2002 21:06:45
 Re: NAA Points problem? in reply to Gary Wilkerson, 11-15-2002 08:06:38
Make sure you have a resistor in the circuit going to the coil. (the proper resistor)
raytasch
11-15-2002 17:58:22
Gary, change the points and condenser. Purpose of the condenser is to protect the points.
ray
