Wagner Loader on an NAA
Gary Wilkerson
11-15-2002 09:18:45
My father gave me a Wagner loader that came off of his 8N.
It looks like it will be a stright forward install as the rear mounts have several bolt options, although I will need to modify the the plat the mounts in the front.
Any thing I should be aware of? The tractor has a piece on the front of the crank pulley that looks similar to the slotted mechanisam used to crank start older tractors. I believe I need to attach a sheeve with four separate contact/rubber connections. Is this correct and how doess it attach to the crank/pulley?
Gary
Mike W
11-22-2002 21:18:35
 Re: Wagner Loader on an NAA in reply to Gary Wilkerson, 11-15-2002 09:18:45
You need the drive shaft to connect the pump and the motor together and there are two vibration type dampers that do this for you call any ford parts house and they'll line you up,,,word of caution,,,this is a light duty loader do not over do it or you will break the front end right off,,,,Mike
