Ford 8n raidator removal
tim
11-15-2002 11:18:03
i have a 8n that one of th two bottom raidator bolts keeps turning.i got the side with the slot undone,but the other side is giving me problems. any suggestions? thanks tim
Wayne
11-17-2002 10:15:31
 Re: ford 8n raidator removal in reply to tim, 11-15-2002 11:18:03
I believe the bottom bolts are carriage type, i.e. have square shoulders. Either the locking slot or the shoulder have been rounded off. You might use a cutting disk in your angle grinder to just chop the bolt off, then go from there. If it was the bolt shoulder that's rounded, just replace the bolt. If it's the slot that is supposed to hold the bolt still, you'll have to do some repairs to that sheet metal.
Good luck.
