Painting a model 50 John Deere
Dale Spackman
11-22-2002 16:11:29
I'm painting a model 50 John Deere. Any tips on what kind of paint and primer to use to make it look original?Is the fast dry John Deere paint hard to use?
Jeff Oliver
11-28-2002 07:08:54
 Re: Painting a model 50 John Deere in reply to Dale Spackman, 11-22-2002 16:11:29
We are just finishing one also and used the paint and thinner from JD that seemes to do fine. It is a little more expensive than aftermarket paints but does a really good job. I have used some from the local rural King here ( Van Sickle brand paint) and the colors are so close I am not sure if you can see the difference or not ( I can't)It seems to be good paint though so that might work for you as well. Are you repainting to show it or use it? If you want that high gloss shine be sure you add a little hardener on the last coat.
Have fun!!!
