How tite?
Gordon R.
11-25-2002 10:22:42
What's a good way to tighten the crank nut on a MF 65 deisel? I "snugged" it by bracing a block of wood under the pulley, but after about 60 seconds of running it became loose. How about taking the starter motor off and blocking the wheel?
How "tite" should it be?
Slopoke
11-29-2002 11:30:15
 Re: how tite? in reply to Gordon R., 11-25-2002 10:22:42
Gordon..... Sorry I told you low or reverse; bill b va is correct. It should be high gear. John
bill b va
11-28-2002 09:18:09
put in the highest gear you have lock the brakes and chock the wheels and tighten away .,,,,, ,, i don't know a thing about your tractor but this should work for most .
