Need Help !!!
Wing Ding
12-13-2002 22:15:20
I am ready to start redoing my tractors, I have a Case 930 Lp and a MF 65 gas. They have been sitting for a couple of years. I was doing good at first about starting them ever once in a whilethen got busy ect. Nayway they havent been started in over a year. What do I need to do to get them raedy to go again, any help is appreciated thanks Wayne
Gene Davis
12-14-2002 19:12:32
 Re: Need Help !!! in reply to Wing Ding, 12-13-2002 22:15:20
Hello there! Hook a Diamond T to it and drag it !!!!
CNKS
12-14-2002 11:24:45
If they are inside or even outside and not stuck there shouldn't be much of a problem, particularly for the LP. Put new gas in the 65, squirt some oil in the cylinders of both, wait a while and they should start, if they started easy before. 65 may need a good carb cleaning, maybe a kit. Wouldn't hurt to change the oil first.
HJTF
12-14-2002 18:13:25
 Re: Re: Need Help !!! in reply to CNKS, 12-14-2002 11:24:45
A little starting ether in the air intake sure helps. If you use my product SlipLube in the oil,you never loose the protective oil coating.
case poor in pa
01-10-2003 05:24:35
 Re: Re: Re: Need Help !!! in reply to HJTF, 12-14-2002 18:13:25
the case just start it i wouldnt floor board it for a minit tho.... the mf better get a white cow to pray to ahahahaa im diclaiming what i said as if he owns a mf he mite already pray to a white cow..
