Can Ultra Black Replace a Gasket?
JKC
12-15-2002 05:42:30
About to put the governor housing back on my 1944 JD A. Deere tells me they no longer make the gasket that seals between the housing and the crankcase. Is Ultra Black Gasket Maker gonna be OK to use here and will it do the trick? Any advise is appreciated. Thanks.
kevin
12-15-2002 13:52:38
 Re: Can Ultra Black Replace a Gasket? in reply to JKC, 12-15-2002 05:42:30
you can still get that gasket from deere tell them to put serch on it or drop the (R) on the #
poorerbut
12-16-2002 07:33:23
 Re: Re: Can Ultra Black Replace a Gasket? in reply to kevin, 12-15-2002 13:52:38
Kevin is correct. UltraBlack is really good stuff
to work with, but you can't expect THAT much out
of it. You need the gasket. pb
CNKS
12-15-2002 11:14:37
There are several products that people use. Not familiar with Ultra Black or your governor housing, but you can get the proper gasket material and make one, unless it is very complex.
