Is my block a big paper weight?
eric
12-19-2002 05:01:24
hi! my tractor is an oliver s77. the block has 2 small but visible cracks in between sleve 1 and 2 and ,3 and 4. it is gas. can you still buy these?(a new block) can it be welded as good as new? the sleves are not cracked.
Fred Kobs
12-20-2002 12:57:28
 Re: is my block a big paper weight? in reply to eric, 12-19-2002 05:01:24
Don't know where you are located but if the block needs welded the BEST place in the country to take it is Midwest Cylinder Head in Nevada,IA. I can't stress the quality of work. Their phone is 800 873 8506. Good luck
Jerry B
12-19-2002 06:20:47
The cracks at the top of the block between the sleeves are no problem. If the cracks are at the bottom however, that is a different story.
If you are truly worried about the cracks then you can have them welded and machined.
