Case 530ck clutch
carlos
12-29-2002 10:35:44
my tractor does not seem to have any power when i put it in gear. the clutch does not seem to do anything. i can put it in forward or reverse 1st or 2nd gear with or with out the clutch in. the clutch is very soft it is hydraulic. the tractor was stuck in the snow today and all i was able to do was rock it a little back and forth. does it need to heat up are there any adjustments to the clutch that i can do? do i have to split the case to replace the clutch plates? any info would be great .
thanks.
