Ford 2N
Dan Eby
01-02-2003 11:34:18
I have a Ford 2N (I think) and there is water in the oil. Is this tractor salvageable? Is there a freeze plug in this tractor that may have popped or is the block cracked?
Russ Heath
01-02-2003 22:08:29
 Re: Ford 2N in reply to Dan Eby, 01-02-2003 11:34:18
this engine uses sleeves and could be leaking around one of the sleeves.
Dennis Benson
01-02-2003 15:30:39
It could be condensation or rain water, it could be a head gasket, or it could be a crack. Try a compression check and test the pressure in the cooling system. If the cooling system has antifreeze, check to see if the water seems to have antifreeze in it.
