'43 Farmall H wide front
Don Davis
01-04-2003 21:53:20
Anybody know how to easily remove and reinstall the bolts that hold the steering piece on the bottom of the vertical steering shaft that comes through the bolster? There are three through bolts that go through the plate on the bottom of the steering link that then go through the cast steering piece that the drag link connects to. I had to take the cast piece off to weld it. The bolts can be pushed up into a cavity in the large cast piece that the bolster bolts to but how to get the bolts back in is the question.
