3.3 liter V6 spark plug replacing
fred
01-06-2003 15:07:46
I know this request has nothing to do with tractors. However if anyone could answer I would be greatly appreciative. How would I go about changing the rear 3 spark plugs on my 91 dodge caravan v6. There is definitely not enough room to get in the way it sits.
John Hayward
03-31-2004 18:33:03
 Re: 3.3 liter V6 spark plug replacing in reply to fred, 01-06-2003 15:07:46
I just replaced the sparkplugs on my 3.3L '95 Grand Caravan. Based on the postings and my own attempt from underneath I think the easiest way is from the top removing the plenum. I could not remove the sparkplug boots from underneath (and was not sure about being able to remove the plugs themselves). It is just a lot easier not having to deal with crud falling on your face.
Here are the major steps I took:
0) Wait for engine to cool and disconnect the battery.
1) remove the 4 bolts securing the "distributer" - this is required to gain access to the 4th bolt on the plenum.
2) remove the 4 bolts securing the plenum.
3) remove the bolt from the alternator bracket to the plenum.
4) remove the hose between the air filter and the throtle to gain access to support clamp and pipe to exaust both on the drivers side of the plenum.
5) remove the two bolts securing the pipe from the exaust to the plenum - do this at the top as the top bolts are less likley to be rusted. These are near the firewall and the bolts face up.
6) remove the bolt on the support bracket on the drivers side below the plenum.
7) disconnect a wire mounting on the back passenger side of the plenum.
8) remove two hoses connecing to the plenum.
At this point you can move the plenum back away and get good access to the sparkplugs.
My gasket fell apart - however Auto zone had a replacement for $3.99 and Murrys had one for $2.67.
One recomendation - once you have the plenum moved you might want to put a rag or paper towel to catch any crud from falling down into the intake manafold.
Hope this helps.
Steve LeTourneau
03-30-2006 21:50:21
 Re: Re: 3.3 liter V6 spark plug replacing in reply to John Hayward, 03-31-2004 18:33:03
I followed your instructions and they worked very well. During the process, I damaged a couple of hoses that were very brittle and I had to replace them as well.
When I start the engine, I hear a very loud, high-pitched squeal. It is so loud that I have to wear ear plugs. Also, the idle is running very fast. I am guessing that there is a vacuum hose that is either cracked or disconnected.
The noise is coming from the passenger side of the engine.
I've removed the plenum again to check for any loose or disconnected hoses but could not find any.
Has anyone else encountered this situation?
If so, do you know the cause/solution?
Any tips are appreciated.
Thanks!
-STL
Mark Mullins
09-07-2005 22:56:30
I replaced all plugs and wires. Changed the oil and filter also air filter. Theengine runs fine whren movingbut, with car in gear and at idle it run horribly. Wants to jerk back and forth. I checkrd my firing order and it looks right.
Reggie Cole
01-09-2004 19:51:32
Where can I find a GM V6 conversion kit for my 800 Ford tractor ? Thank for your help
dirk
06-26-2003 10:57:27
Manual calls for removing wiper assembly and intake plenum and so forth. Sounds a lot easier than jacking up the vehicle, or dropping hte engine. But it still sounds like a big hassle.
Jetman
01-30-2003 11:39:33
I had a Caravan 3.8. I managed to replace the back plugs by accessing them from underneath the vehicle. Lots of cuts and nicks. Later, during work on the wiper motor, I found out that you can remove the whole tray above the back of the engine rather easily. I'd do that trick if I were to replace them again. The 95 may be the same. The plugs were easily accessible. I sold the vehicle. Was a lot like an old tractor, working on it all the time.
Jerry A.
01-08-2003 08:47:37
I had a '95 Caravan with the same problem. I changed the plugs once. It can be done!
I put the front wheels on ramps and crawled under the van. It's tough to reach, but the plugs can be changed (at least on that model year). Thank goodness there's only 3 to reach.
Dennis Benson
01-07-2003 07:46:51
I checked my Haynes manual for the 1984-1989 Caravan I used to have, and it sidesteps the question. It says to use standard spark plug wrenches, and don't scratch the paint. However, I used to be a mechanic, and I would assume the previous post is correct, that you would have to change them from underneath. Just jack up the front end, set it on stands, get a comfortable creeper, turn on some music, get a beer, roll under the van, make sure you're comnfortable, and change the spark plugs.
BOB SHIELDS
01-08-2003 19:37:03
 Re: Re: 3.3 liter V6 spark plug replacing in reply to Dennis Benson, 01-07-2003 07:46:51
Had a Chevy Z26 WITH A V6 BEST way Ifound to replace the 3 plugs next to fire wall was to loosen the motor mount and ease engine down on a floor jack good luck
Greg(Mo)
01-06-2003 19:53:55
On some of these new vehicles, the easiest way to
replace those plugs is to pull off the intake
plenum. Normally, the gasket remains intact and doesnt need replacing.
Big red 460 diesel
01-06-2003 18:04:24
My mo has one and me and my dad took all day to replace the back plugs! He is also a master mechanic! What we did was jack up the van as high as we could and reached up there thats about all you can do. Unless you have a hoist then you can get them guite easly. Good luck there a bear!
