Hydraulic problem on 1750 Oliver
Ted
01-09-2003 12:49:29
When I installed a loader on my 1750 Oliver, I discovered a problem. When I place a very heavy load on the loader, the hydraulic system locks up rather than lifts. To get it to lift again, I need to engage and disenage the lift several times. While it is locked up, the system functions fine for the three point hitch and for the other ram so I know the pump is fine. I assume I have a pressure release valve or bypass valve malfunctioning. Any suggestions on where to start looking for the problem and advice on whether or not this is something an amature mechanic can repair will be appreciated. Thanks!
evielboweviel
01-10-2003 08:32:13
 Re: Hydraulic problem on 1750 Oliver in reply to Ted, 01-09-2003 12:49:29
post this on Oliver board. hopefully Shep, WFE or somebody else can help
