Gas tank
Ron Schueller
01-16-2003 12:26:33
Does anyone know how to clean the inside of a gas
tank? It has very little rust but gas inside was
in there for 25 years.
Jim Z
02-18-2003 05:21:39
 Re: gas tank in reply to Ron Schueller, 01-16-2003 12:26:33
I have tried every trick in the book for dried gummy gas. The other day i bit the bullet and spent $85 on 5gallons of carburator. i put it in a tank that had about a quarter inch of hard and gummy gas i let it soak for 3 days then draind it and blew it out with the pressure washer It LOOKS LIKE NEW NOW and i can reuse the cleaner in many more tanks well worth 85 dollars and was the easiest tank i ever cleaned And it was the worst to start with
Rick
01-21-2003 11:02:31
A little water and some pebbles. Shakes a whole lot (good job for kids) and them seal with gas tank sealant for Eastwood Supplies.
Slowpoke
01-16-2003 23:00:29
Acid is not healthy, but I think muriatic acid is available at swimming pool suppliers. Otherwise remove the tank, put in a few handsfull of roofing nails, aquarium gravel, or the like and a gallon or two of water. Strap it down in the back of the pickup or car trunk and drive it around for a week, preferably over rough roads. Or you can shake it by hand for a while if you have the arms to do it. And be sure to keep the cap on! :)
Ryan Free
01-16-2003 19:33:33
There is a kit you can get called Kreem (cream).
1. Meratic acid & Hot Water(can't spell)(Eats rust/old gas)
2.Rinse well with water
3.Rinse w/ dry gas (dry's out tank)
4.Apply Kreem to inside of tank with a few coatings over the period of a few days. Make sure you coat it well because nothing will eat threw this stuff!!
Just my $.02
case poor in pa
01-18-2003 09:55:42
 Re: Re: gas tank in reply to Ryan Free, 01-16-2003 19:33:33
www.porshop.com has a whole system to clean them and seal them around 50.00 will do a car tank less for smaller tanks cleans out the varnish rust and seals them.. i just got some havent tried it yet to dern cold here in pa also 1 dude was tellin on here he puts a lb of deck screws in the tank and strpas it to his rear tractor wheel and goes to mowing a field says it works good knocking the rust off proably should put a little liquid in there to i imagine when you do that
