1963 4000 Ford
Bud Vance
01-17-2003 10:07:22
I have a 1963 4000 Ford gas burner with a 4 speed transmission. My question is several years ago my father converted it from 6 volts to 12 volts by using a GM alternator. Can I replace these with a 12 volt generator and regulator and the tractor still be consider original? The diesel version was 12 volts.
RickB.
01-17-2003 15:58:41
 Re: 1963 4000 Ford in reply to Bud Vance, 01-17-2003 10:07:22
Will it look original? Yes. Will the purists consider it to be original? Of course Not! Will you like the look of a 12V generator better than that Delco hanging off the side? Probably! Note the Ford 12V systems were negative ground.
