Belt pully
Scott in MO
01-17-2003 18:38:40
I was wandering has anyone ever restored a belt pully on a farmall H using wood as a surface rather than paper maybe oak or maybe some other kind of hardwood? I know paper was used originaly. I understand the cost to restore with paper is rather EXPENSIVE. thanks for any help.If icould find out what kind of paper is used i would try to restore it myself.
Rick
02-19-2003 17:30:05
 Re: belt pully in reply to Scott in MO, 01-17-2003 18:38:40
Scott,
I am just finishing up restoring a belt pulley for my JD LA. I tried several types of wood, including oak, but they all eventually split. Think I have found a way to do it, but not sure until completely finished and tried on the tractor. Have you found any resources on the paper? Am also thinking that if my method works, it might be something I would like to do on the side -- restoring pulleys for the old tractors. Have already gotten positve feedback from my own community. What do you think? Have you ever heard of anyone doing this as a service? Also, exactly where are you located in MO? We live outside of Cape Girardeau.
Scott in MO
03-20-2003 19:17:00
 Re: Re: belt pully in reply to Rick, 02-19-2003 17:30:05
Rick Scott in Mo sorry I did't get back with you i don't always look at all the forums I'm still experimenting with belt pullys though . Also I'm located in the St. Francois County area . Feel free to email me if you want to . THANKS
Ray Sensney
06-04-2006 07:20:26
 Re: Re: Re: belt pully in reply to Scott in MO , 03-20-2003 19:17:00
I"m trying to repair the pully on a McCormick Deering hammer mill. Mice have eaten about 25% of the paper. Do you think its possible to fill with epoxy?
Thks
raytasch
01-19-2003 05:56:05
Scott, I have not seen a wooden pulley on a tractor but I do remember lots of wooden pulleys on the line shafts in my grandfathers flour mill. I can think of no reason why a good wood worker could not do what you mention. If it is just a servicable pulley you are looking for there is one advertised somewhere, I believe on YT site. I have an old pulley I pulled from a Ford that is serviceable that I would cut loose right (cheap) if it would fit your application. It is just taking up space on my shelf.
ray
