Old tires
Jerry
01-18-2003 09:37:44
I was wondering if painting old rubber tires with drain oil would soften them?
BOB
02-05-2003 18:36:42
 Re: old tires in reply to Jerry, 01-18-2003 09:37:44
Go to local speed shop they will have tire softner or you can use Zylene home depot.BOB
GPWT
01-21-2003 14:28:39
If tires are hard from age and sunlight, it's because oxygen in the air and ultraviolet in sunlight has worked on the rubber and partially destroyed it chemically. You can't reverse it.
KEG
01-20-2003 20:34:16
Jerry,
Try Black Tire Paint from M.E. Miller (>Link
KEG>Link
Greg(Mo)
01-20-2003 17:48:55
Petroleum products attack rubber, and make it swell. If you are interested in prolonging the tires life, I'd suggest using brake fluid.
Slowpoke
01-19-2003 00:37:53
If you're trying to soften them in hopes of removing weather cracks, I don't think anything will work. But you can try some of the auto tire restoration products from the local auto supply, Eastman's or JC Whitney. Or ask a used car dealer what he uses. I sometimes use NO-Touch in a spray can. Spray it on and it shines itself and looks pretty good.
Dennis Benson
01-18-2003 09:45:36
Just wondering why you wanted them softened? I don't know as oil will, but if they are scrap tires they can be softened with alcohol, I don't remember the exact kind, but it softens rubber to shread easier and to remove it from the steel belting, and leaves the rubber caemically ok for making into new rubber. But I might be getting off your idea with the recycling of rubber. I don't know of a way to soften it to make it useable.
