1945 VAC Case Tractor
Beverly Jackson
01-19-2003 09:10:58
Need to find a service manual for a 1945 VAC Case. Need manual that shows the torque sequence and amount of torque for the head. Also need to order parts, carburetor kit,head gasket, sediment bowl kit. Know that engines didn't change much back then, and could I use parts from a later model? Any help will be greatly appreciated.
Bev
lonnie
08-01-2004 20:48:57
 Re: 1945 VAC Case Tractor in reply to Beverly Jackson, 01-19-2003 09:10:58
Am looking for a repair manual for a 1945 VAC Case tractor.
Teresa
01-21-2003 01:28:48
The torque is 60 to 65 foot-lbs. Begin at center stud and tghten from center outward, alternating sides (le ft of center then right of center, left, right etc) - make sure all studs are tightened evenly. After having run for about 1 hr. & has reached operating temp, retighten stud nuts. The manual says to use T-132 extension on your torque wrench. Happy wrenching!!
Bev Jackson
01-22-2003 07:34:26
 Re: Re: 1945 VAC Case Tractor in reply to Teresa, 01-21-2003 01:28:48
THANKS SO MUCH FOR THE INFORMATION
BEV IN AJ AZ
Slowpoke
01-19-2003 10:19:51
Try the Case/IH dealer first. He has a catalog for manuals, and a computer parts list. At least you will get an idea of costs for available manuals & parts. Expect to pay the same for new after market tractor part as you would for new auto/pickup parts, depending on the model.
case poor in pa
01-22-2003 17:31:19
 Re: Re: 1945 VAC Case Tractor in reply to Slowpoke, 01-19-2003 10:19:51
ebay has lots of manuals don l has lots of parts email manifold@smig.net
