Fixing metal emblems
Randy
01-24-2003 05:46:36
I got a good deal on some 300 metal emblems because most of the pins on the back were gone.
Does anyone know a good way to put pins back on?
I was thinking of maybe just putting them on with some type of good automotive emblem adhesive. Could a nail be soldered on? I think brazing would warp or discoler the emblems. Thanks for any info.
Slowpoke
01-31-2003 01:31:31
 Re: Fixing metal emblems in reply to Randy, 01-24-2003 05:46:36
Try a magnet on the emblems. If it sticks, you can probably solder small nails. If it's not magnetic, it might not take the heat from soldering without melting. I read your post as your having multiple emblems. Practice on the worst one. Try JB Weld with nails. Can a small recess be made just big enough to set the nail head in and epoxy? Use a mike and measure an original pin and find a nail the same diameter. Nails are available as small as 1/2 inch long with regular nail head.
Gene Davis
01-25-2003 18:02:37
Have installed them with a little clear silicone.
