Sandblasting main body
Dan
02-05-2003 10:21:02
Due to a small air tank, I have been using a wire brush to remove most of the paint from my B. I sand blast the area's I can not get with the brush. This works fine on the smaller parts, but now I am getting ready to do the frame. would an "industrial" compresser work? The kind to run jack hammers?
Dan
Rick
02-09-2003 18:45:37
 Re: Sandblasting main body in reply to Dan, 02-05-2003 10:21:02
Check out www.Eatoncompressor.com These guys built and sell direct. They use a true H.P. motor[a 5H.P. is a true 5H.P. not a 1.5h.p. running at a high rpm] not like most air compressor companies sell. They use cast iron pumps, which are heavy. I bought a 5h.p. single stage and this is more compressor that I ever had with my old 5h.p.[which was a brand name]. They will help you with your needs and they are priced right!!
Dennis Benson
02-05-2003 11:10:04
Yes, an industrial sandblaster that runs jackhammers will work, were you planning to rent one? If so, they can tell you if it will work. From what I understand a 5 hp, 2 stage compressor will run a sandblaster. I'm putting together a Quincy 325 that I ground the crank and replaced the bearings, rings, and did a valve job, because I want to use it for sandblasting. I understand it is the smallest I would want to use.
Dave_Id
02-06-2003 11:55:12
 Re: Re: Sandblasting main body in reply to Dennis Benson, 02-05-2003 11:10:04
I have a 5 hp 2 stage compressor, and in order for it to keep up, I had to get a 3/32 tip.. The 1/8 was too big, then there is the problem of moisure buildup. If you are doing just small areas, moisture may not be a concern.
