How to bring the serial numbers up on the serial # plate
Ben
03-01-2003 07:52:35
On my 47 JD A we are not able to read the serial numbers. Does anyone know a way to make them more readable? Thanks, Ben
Don LC
03-05-2003 03:49:42
 Re: how to bring the serial numbers up on the serial # plate in reply to Ben, 03-01-2003 07:52:35
Use a black magic marker ,then wipe over it with a cotten clouth wraped tightly around your finger....
Ben
03-04-2003 02:50:10
Thanks guys... We are going to try again this weekend. using pencil lead we think it is 580901 which makes it a 47 A. The first number is a guess.
thanks again
Ben
Jack
03-03-2003 20:33:51
Chalk works quite well also-go over the numbers with white chalk then wipe off with you finger. If there is any indentation at all it will stand out and be very readable.
dave
03-01-2003 14:49:40
Clean the serial # plate down to the bare metal and paint over the numbers with black or some color that will stand out. Then while the paint is still wet wipe the plate off with a staright edge of some sort, which leaves the characters filled in with paint. It worked on my old tractor.
John
03-02-2003 15:28:19
 Re: Re: how to bring the serial numbers up on the serial # plate in reply to dave, 03-01-2003 14:49:40
Ya I had the same problem ..I sanded the area well and wiped it clean ,then took a lead pencil and rubbed it over the area then wiped it off with my finger, low and behold there it was, cheap ,quick and no mess
MARK TX
03-02-2003 19:51:23
 Re: Re: Re: how to bring the serial numbers up on the serial # plate in reply to John, 03-02-2003 15:28:19
THINGS YOU NEED MASKING TAPE AND A PENCIL WITH ERASER.PUT ONE STRIP OF MASKING TAPE ON #'S, PRESS DOWN WITH ERASER AND PUT LEAD ON YOUR FINGERTIPS AND SWIPE ACROSS MASKING TAPE ONE WAY AND THEN THE OTHERWAY .WALA NUMBERS. GOOD LUCK.MARK
