Hot Water Pressure Washers
Michael Behr
03-04-2003 18:30:09
What will a hot water pressure washer do for you that cold water will not, other than keep you warm in the winter.
Try washing your hands in cold water---
03-04-2003 19:39:04
 Re: Hot Water Pressure Washers in reply to Michael Behr, 03-04-2003 18:30:09
Then use hot water and notice how much better the grease/dirt mixes with the soap and goes away, added benefit is that the warm water washed metal dries a little faster to help prevent rust forming.
Joe from mi
03-05-2003 17:47:38
 Re: Re: Hot Water Pressure Washers in reply to Try washing your hands in cold water---, 03-04-2003 19:39:04
Hot water with a cleaner works best. but to add a note, a good steam machine is tops. to tell the truth I havent seen one in awhile but can remember when it seemed like every garage had one.
