Front end repair
Jim Williamson
03-06-2003 07:03:11
My kid fell of my 2N which ran on auto-pilot into the deck.. Smashed the radiator and grill, but my real problem is the front axle. It was dislodged and loose on the kingpin. The front wheels bith point outward. I thought by reseating the axle forward it would correct that, but there isn't enough clearance. The steering sectors seem to be properly aligned and nothing is bent. I don't think the axle is bent. It wiuld crack wouldn't it. Can anyone help?
jake
03-06-2003 07:56:32
 Re: Front end repair in reply to Jim Williamson, 03-06-2003 07:03:11
It's not likley the front axel is bent. Examine the front support assembly, it is made of stamped metal bolted to the front of the engine and the pivot pin is bolted to it. The impact probably bent the rear portion causing your problem. Walts tractor parts has them. Hope this helps
