Fixing Oil Seal Groove in Crankshaft Pulley?
AWB
03-15-2003 05:31:15
My Crankshaft Pulley has a deep groove worn in it where the old oil seal was. Tried some fine emery cloth, but it is too deep to polish it out. What is the best fix for this type of problem?
RickB.
03-15-2003 12:02:11
 Re: Fixing Oil Seal Groove in Crankshaft Pulley? in reply to AWB, 03-15-2003 05:31:15
Speedi-Sleeve, or reposition the seal onto a virgin part of the shaft.
Rod (NH)
03-15-2003 05:58:11
Speedi-Sleeve. Check out the link. These repair sleeves are available from most industrial power transmission equipment dealers.
Slowpoke
03-16-2003 10:09:05
 Re: Re: Fixing Oil Seal Groove in Crankshaft Pulley? in reply to Rod (NH), 03-15-2003 05:58:11
Does each size sleeve require a matching installation tool or is the tool useable for a range of sizes? What is the approximate cost of a sleeve & tool for a 1-3/4" shaft?
Rod (NH)
03-16-2003 15:33:03
 Re: Re: Re: Fixing Oil Seal Groove in Crankshaft Pulley? in reply to Slowpoke, 03-16-2003 10:09:05
Hi Slowpoke,
The installation tool that comes with the sleeve is not worth much. It is a real nickle and dime thing and is unique to each size sleeve. It has one blind end and is quite short. It's worthless for installing the sleeve any significant distance from the end of the shaft. Anything hollow that will go over the sleeve OD and still contact the removable flange on the sleeve will work. I am about to install a sleeve on my AC-B belt pulley shaft. In this case the area that the seal rides on is about 3" in from the end of the shaft. I am going to use a short piece of PVC pipe to install the sleeve. The sleeve I have is for a 1-3/8" diameter shaft. It was fairly pricey at about $25.
Rod
Slowpoke
03-16-2003 20:44:20
 Re: Re: Re: Re: Fixing Oil Seal Groove in Crankshaft Pulley? in reply to Rod (NH), 03-16-2003 15:33:03
Thanks, Rod. I guess it's less costly than getting a replacement shaft, new or used. Probably less trouble, too.
