International super m farm all piston and valve prob:
neal wasdin
03-17-2003 16:09:22
i have a massey furg. farm-all super m not sure of year and unable to find any beneficial numbers to help with parts, it ran hot and the valve dropped and went thru the piston, i need the piston and the valve. need lock pins also, i need help and if anyone has any manuals i would appreciate copys or manual, it is gas ran not diesel. it is a 4 cylinder engine. red original color. serial number on tractor is 89212
it reads super m mccormick farm-all.
CNKS
03-17-2003 18:59:52
 Re: international super m farm all piston and valve prob: in reply to neal wasdin, 03-17-2003 16:09:22
Assuming you indeed do have a Farmall Super M, parts are available from moany sources including your Case /IH dealer. Factory Manuals are available from this site, Case/IH, and a couple of other sources. As YTMag will not allow me to lists competitors names, do a search for "Farmall manuals" and "Farmall parts"
rustyfarmall
03-17-2003 17:44:19
Either you have a Massey-Ferguson or you have an International-Harvester Farmall super=M. These are two completely different manufacturers, in fact, competitors, the only thing that was the same is the color, both were painted red. Once you figure out just what it is you have, finding the parts you need will be easy.
neaL WASDIN
03-21-2003 16:44:49
 Re: Re: international super m farm all piston and valve prob: in reply to rustyfarmall, 03-17-2003 17:44:19
thanks for the clarification on international and massey ferg. all my tractor say's is super m farm-all, nothing on engine parts etc. helps, how do i differentiate the two, apparently parts may be available in your end not mine, i live in a german farming community, and no one can give me any info on the tractor. i'm really at a loss. any help will be appreciated.
rustyfarmall
03-29-2003 13:14:21
 Re: Re: Re: international super m farm all piston and valve prob: in reply to neaL WASDIN, 03-21-2003 16:44:49
You need to re-post your message in the farmall- I.H.C. discussion board, and mention where you are from. You will most likely get more information on that board than what you will need. I think you can leave out the massey-ferguson part.
