Cracked block
no help for all
03-17-2003 17:09:18
my 48 Allis b has a cracked block in a 3rd cylinder, it looks as if has steal sleeves that could be replaced, is this true, if not is there a way to fix the block
res
03-20-2003 19:58:27
 Re: cracked block in reply to no help for allis, 03-17-2003 17:09:18
If the block is cracked a new liner won't do much. If the linner is cracked that is different. Blocks have been repaired in many different ways some good and some not good. I have sceen Allis blocks welded, bolted, and a system of drilling and taping along with some repaird with body putty or other such epoxys. good luck
Gordon
03-17-2003 19:35:40
pull the liner and replace it you may as well install all 4 liner assembles, and go thru the head
