Broken gear
Henk
03-19-2003 18:45:28
I have a Ford Ferguson 6 volt which has a broken first gear it runs but has a clonk in it. How do I get to replace the gear Do I have to go from the top where the gear shift leaver is or doI need to split the tractor.
Alton
04-03-2003 19:39:45
 Re: Broken gear in reply to Henk, 03-19-2003 18:45:28
had two gears in an 8n to break teeth, parts cost $500.00+
Don-WI
03-22-2003 09:13:06
Would probably be easier (and cheaper) to buy a rear end from a bone yard. I have an Oliver 1755 which had a few gears bust and bind together so it wouldn't move. It was cheaper for the shop to swap out the whole rear-end. Now has the rear of an 1855.
Jerry B
03-21-2003 14:50:02
Not only do you get to split the tractor, you get to remove most of the gears and shafts from inside the transmission.
Get an I&T manual. Truly the best "help" you can get when just starting out.
