Fuel Gauge on JD 2020
Larry W
03-20-2003 17:29:38
Just bought a JD 2020. I am trying to get the fuel gauge to work. The previous owner removed the wiring when he replaced the raidator. Here my question. I have 3 spade type posts on the gauge and 1 spade post on the sender. How do I connect all this up to make this work. I bought a new gauge and the sender seems to have the right resistance in ohms when tested.
JMS/MN
03-21-2003 00:07:08
 Re: Fuel Gauge on JD 2020 in reply to Larry W, 03-20-2003 17:29:38
I would always test the sender first, by grounding the wire going to the sender. That should peg the needle on the gauge. If not, the sender is bad.
