Fluid for the farmall Lift All
Martin
04-09-2003 13:01:41
Does anyone know what kinda of fluid goes in the lift all system in my farmall h?thanks
CNKS
04-09-2003 17:48:21
 Re: Fluid for the farmall Lift All in reply to Martin, 04-09-2003 13:01:41
SAE 30 non-detergent.
Dave_Id
04-12-2003 18:08:55
 Re: Re: Fluid for the farmall Lift All in reply to CNKS, 04-09-2003 17:48:21
....but a lot of people use HiTran if their unit it in good condition to prevent cross contamination with other tractors.
CNKS
04-12-2003 19:07:06
 Re: Re: Re: Fluid for the farmall Lift All in reply to Dave_Id, 04-12-2003 18:08:55
Yes, but I think most people who use tractors regularly already know that.
Dave_Id
04-13-2003 06:47:00
 Re: Re: Re: Re: Fluid for the farmall Lift All in reply to CNKS, 04-12-2003 19:07:06
I didn't mean to step on your toes, I know that it's obvious to you and I and most others, but there are many people out there who don't know this. I was just adding a point to your post, if I had realized you were that sensitive, I would not have posted.
CNKS
04-13-2003 11:45:28
 Re: Re: Re: Re: Re: Fluid for the farmall Lift All in reply to Dave_Id, 04-13-2003 06:47:00
I'm not that sensitive. If the person posting has only that tractor, then 30 weight is fine. Farmers and people who use the equipment all the time know what to use. No offense taken. Next time I'll qualify by saying "--unless you share equipment with another make/later model of tractor,etc--"
John Kilpatrick
02-03-2006 16:38:18
 Re: Re: Re: Re: Re: Re: Fluid for the farmall Lift in reply to CNKS, 04-13-2003 11:45:28
This conversation is ancient history but just in case: I'm one of those 'new to the game' people; my Farmall H manual says the lift all uses the same fluid as the trans / diff - which the manual says should be 90 weight. My lift all works for about 20 minutes or so, then gradually loses power until it won't even pick up the blade. I've just drained some very dirty fluid - more like gunk - and replaced the tran/diff with 90 weight. No improvement. I'm looking for answers ...
