Torque settings
Andy
04-11-2003 19:53:59
Assembling a 41 farmall B motor. Bought Felpro gasket kit. The head gasket has a stamped message:
"sealer / retorque required".
What does this mean? Anyone?
Andy
04-12-2003 18:49:19
 Re: Torque settings in reply to Andy, 04-11-2003 19:53:59
Advise taken.... really appreciate it! Thanks!
CNKS
04-12-2003 14:23:20
The head to block on your C113 engine is rather hard to seal. Felpro is probably ok, but if you have problems, get a Case IH gasket, as this is a place where OEM is superior. Torque the head in increments, from the center out to a final 80 ft lbs, run it a while and retorque. If you have a service manual it will probably say 60 ft lbs --this has been updated to 80.
jake
04-12-2003 07:45:52
After the engine is started and warmed up it must be retorqued to specs. You will find that all the head bolts will turn 1/2-1 turn furthur. Failure to do so will result in water & comression leakage.
