Cleaing block surface
Keith
04-14-2003 15:05:49
I just took my head off to be redone and am wondering what you guys use to clean off the top of the block before reassembly.
Ronny
09-18-2005 18:50:58
 Re: Cleaing block surface in reply to Keith, 04-14-2003 15:05:49
Keith,
The best way I've found to clean blocks and heads is with a scoth-brite pad by 3m, part #051131-07451, holder part # 3m 924. It will make it as shinny as you can get with out crome. It will not cut your metal,. If you have a diesel engine with pencil injectors be sure and remove them first. Hope this helps. cost about $2.50 per part!
Ron
CNKS
04-14-2003 17:35:05
You asked what I use, not if it is correct. Assuming the engine is NOT disassembled, I use a combination of a rigid scraper, pocket knife, and a small wire brush, being careful not to damage the surface, and try to avoid getting anything into the cylinders. Plus frequent use of a shop vac. If you have an empty block, scrape and scrub away, just don't scratch the surface.
