Cub wont start
fed up
04-14-2003 19:09:35
have a farmall cub with distributor and coil have good fire at plugs, turns good but wont even try to start help!!!!! !
Uncle Bob
04-24-2004 17:53:44
 Re: cub wont start in reply to fed up, 04-14-2003 19:09:35
Is the oil-bath air cleaner obstructed? Are you getting enough air at the carburetor?
Bigdog
04-16-2003 17:46:56
If you have good spark and it's timed right, the only remaining part of the equation is fuel delivery. I'd clean the carb and put a kit in it. Then check for adequate fuel supply to the carb. Do you see any crud floating around in the tank?
