Fordson F Clutch, HELP!!!!
David O. Sall
04-15-2003 12:50:55
I am restoring a 1919 Fordson "F" & i am having problems with the clutch, I belted the tractor, & got the clutch to free using diesel to clean the clutch housing out, I ran the clutch several times & it worked okay, Today i filled the gearbox with 30W oil, & now the clutch will not disengage again???? Any suggestions before i split the tractor? I am also looking for some extra fordson "F" parts, Radiator core, Cast iron hand nut for the cap, cast iron manifold brackets for the exhaust pipe, & maybe even a manifold... Any help would be greatly appreciated,
David Sall
Winger Minnesota
Dave@NY
05-16-2003 18:48:51
 Re: Fordson F Clutch, HELP!!!! in reply to David O. Sall, 04-15-2003 12:50:55
We have a 1927 F,and have learned that unless the clutch pedal is latched down when you park it,it will have to be started and run till the engine is hot before the clutch will work again.A couple of old-timers told me to grind it into gear. I have a hard time agreeing with that one.
