Farmall 504 gas
Sean Dickson
04-18-2003 13:12:15
The steering wheel turns but the steering linkage and rods dont turn. The first rod and u-joint seem to have fallen away from under the dash alittle. When I push everything back into place it all turns, down to the wheels. Is there a pin that could have broke?? I hate to tear everything apart if I dont have to. CAN SOMEONE HELP?????
gmiller
04-23-2003 11:34:21
 Re: Farmall 504 gas in reply to Sean Dickson, 04-18-2003 13:12:15
There is a roll pin up in the dash where the shaft pushes in. Its a booger to fix-lots of skinned knuckles.
Sean Dickson
04-23-2003 15:27:15
 Re: Re: Farmall 504 gas in reply to gmiller, 04-23-2003 11:34:21
Thank you very much gmiller!!!!! That was the problem!!! Alittle PBlaster and alot of cussing and my wife and I had the thing done and put back together. Its hard when your a city farmer working on these old things for the first time.
