Uncles 504 Gas
Don Dittmar
04-20-2003 14:58:18
I am tryiing to help my Uncle work on his 504 tractor. The hydraulics is where I am running into trouble. The loader will pick up for a ways then stop, soon it will pick up a little more then stop. If it is below freezing they dont work at all. Also the power steering is acting up. You have to crank the steering wheel real fast and the tires turn real slow. All of a sudden the wheels stop turning at all....once you work your way through the stiff point the turn freely again. HELP!!!
JMS/MN
04-20-2003 23:43:37
 Re: Uncles 504 Gas in reply to Don Dittmar, 04-20-2003 14:58:18
Do you have water (ice) in the system? Get the tractor inside to thaw out, check if the hydraulic oil is milky- that indicates water in the oil. Also time to change the hydraulic filter. Anytime you have hydraulic problems, the filter is the first thing to check as long as the dipstick shows enough oil in the system.
