Farmall super a
Tim-,Wisconsin
04-26-2003 20:59:42
Need to replace crankshaft seal would appreciate any tips for removal of crank pulley
chester f/wisconsin
04-29-2003 16:29:49
 Re: farmall super a in reply to Tim-,Wisconsin, 04-26-2003 20:59:42
Jim,
You can find a lot of helpful people on the IH Farmall forum. Having said that, I have replaced that seal on my Farmall A a wile ago. this is a tough pully to get off. The IT manual says to heat the pully, I didn,t do that you need a two arm gear puller be aware that pulling to hard can break the inside lip, using a split bearing puller is recomended.
Good luck!
