AC D17 hydraulic leak
David Young
04-27-2003 07:19:30
any help in this matter, would be greatly appreciated..... i currently have an ac d17 series II,and when i fill the hydraulic reservoir with fluid and run it for a while, the transmission fluid boils over and out the breather hole on top of the trans. gearbox, then slowly the hydraulics fail to hold and gradually fail. and when the tractor is parked it seems to be leaking hydr. fluid bad out from under the rear axles? again thank you for ANY help you can give with this problem!
JMS/MN
04-29-2003 01:05:34
 Re: AC D17 hydraulic leak in reply to David Young, 04-27-2003 07:19:30
Don't know this for a fact, but seem to remember some posts about an internal hose that feeds the lift arms, hose could be leaking and the oil would go into the differential. Check with a parts manual if this is involved with your tractor.
