8N head gasket
TIM
04-29-2003 10:59:30
Just curious to see if anybody had some tips on head gasket replacement. My tractor is a 1948 8n,I freshened it up last winter with new rings and gaskets,but now it is blowing antifreeze smelling "fog" out the exhaust,so i assume the head gasket didn't seal. Is there some sort of sealer that I should use to get a better seal. The mating surface on the block was clean and I had the head milled because it was warped a little,but it is very flat now..Got any suggestions???
Thanks,
Tim
jake
04-29-2003 21:40:55
 Re: 8N head gasket in reply to TIM, 04-29-2003 10:59:30
Did you retourque the head bolts after the engine was hot, failing to do this will cause that problem.
TO-35 MAN
04-29-2003 17:48:24
I use a product called copper coat it's available at most auto parts stores in spray and brush on cans.Don't forget to check for cracks and use proper head torque procedures.
Tim
04-30-2003 04:31:01
 Re: Re: 8N head gasket in reply to TO-35 MAN, 04-29-2003 17:48:24
Thanks guys,I'll change the head gasket this weekend and try both of those fixes. I thought about using the copper coat stuff on it when I was putting it together,but didn't. It's just a working tractor for now,eventually I'd like to get something a little newer to use and restore the old ford properly.
