Electrolytic parts cleaner.
AWB
04-30-2003 18:33:03
I have been using an electrolytic parts cleaner with a solution of Washing Soda as the electrolyte. Can't find Washing Soda lately...what would be a good substitute? Thanks.
D13
05-06-2003 18:11:55
 Re: Electrolytic parts cleaner. in reply to AWB, 04-30-2003 18:33:03
Found washing soda, Arm and Hammer brand, in the laundry detergent isle at Meijer and Kroger.
Drano doen't need electricity to strip paint, it's lye. Be careful, it will eat non-ferrous items (like copper, brass, nickle plating...). It will wokr as an electrolyte.
The link above is very helpful. I do small parts this way. follow the instructions EXACTLY and remember to keep it ventilated due to the gasses.
Dan in Ore
05-03-2003 07:11:01
I used crystal "Drano" when I had mine set up.
Get everything set up and turned on. Then add the Drano until the reading on the ammeter is 10 amps. Leave it overnight and the next day you have a rust-free item.
Dan
Hendrik
05-01-2003 01:17:40
Sodium Hydroxyde (NaOH) was recommended on this forum a while ago and I've used it with good results. It seems to remove paint better than washing soda. Sodium Hydroxyde is hard on your skin so use gloves and eye protection!
George
05-01-2003 23:56:19
 Re: Re: Electrolytic parts cleaner. in reply to Hendrik, 05-01-2003 01:17:40
I have used Cascade dishwasher detergent powder with good results.
Kenrat
04-30-2003 20:04:57
I have no idea but what is electrolyte parts cleaner and what kind of parts do you use it on ? Thanks Ken
Peabody
05-01-2003 05:36:03
 Re: Re: Electrolytic parts cleaner. in reply to Kenrat, 04-30-2003 20:04:57
Check this out:
http://www.bhi.co.uk/hints/rust.htm
