McCormick Deering 15-30
Rick Hopkins
11-28-2001 21:34:46
I'am rebuilding a 1930, 15-30 it has a 22-36 eng.Can someone give me advice?I just want to ring it,but rods will not come out through cylinder.But I can get piston up enouf to put rings on it.I donot want to pull the crank.Is this how you have to ring these engs.Sleves are good.Also I need a fuel tank,ordered one from Kinsinger Eng. Service but Iam not happy with it.Also need fenders.Any help will be greatly apprechated.
Farmer-Gene
11-30-2001 18:22:40
 Re: McCormick Deering 15-30 in reply to Rick Hopkins, 11-28-2001 21:34:46
Rod and piston assy will come out the bottom through the side hole in the block. When you put them back in, then push the piston up above the block, install rings and use ring compressor and drive back down.
Rick Hopkins
04-08-2002 21:42:38
 Re: Re: McCormick Deering 15-30 in reply to Farmer-Gene, 11-30-2001 18:22:40
thanks,Farmer-Gene and BILLD for your help.got her back togather and started her up today!!! man what a great feeling,it is to here something like this run for the first time in 30-40 years.it was a lot of work but it was worth it.iam going to finish putting it back togather,fueltanks,ect.and run it for a while to get all the bugs out of it then take it back apart and sand blast the frame.guys thanks again fore your help.
BillD
11-29-2001 13:34:43
The pistons will come out the bottom with out removing the crank at least the 4 1/2 inch 15-30 did for me with a little manuvering.You really need to take them out to check the sleeve condition and rehone to cross hatch for ring seating Your best bet is to look to the left on your screen and order a shop manual Fenders are available from a couple of places one in Indiana and one in Pa. Both advertise in Gas Engine Magazine
Redtractorman
11-29-2001 07:31:31
You need to post this question on the Farmall forum.
