Case 300 Steering.
tom in so il.
05-10-2003 05:52:02
I have a Case 300 Super wide front.I need to know how to take the "slop" out of the steering wheel. Also, the front wheels wobble when I go down the road.
scottb
05-25-2003 21:14:59
 Re: Case 300 Steering. in reply to tom in so il., 05-10-2003 05:52:02
I have an Allis Chalmers 185 wide front that does the same thing. On mine it looks like slop in the connections on the ends of the hydraulic cylinder that control the steering. However, I don't think that the Case 300 has hydraulic steering. At least the one that I had didn't. I would have someone work the steering wheel back and forth while you look at all the linkages. You should be able to find the problem spot.
Good luck. The 300 is a nice tractor. I kind of miss it.
