PTO
rock Hauler
05-10-2003 19:25:51
I've got a 1958 five star MM gas, does anyone know what horsepower this tractor has, and what h/p is it putting to the PTO? I'm using a pull type bush hog and it has twisted two PTO shafts already. The bush hog is 60 HP gear box, can anyone tell me what is causing this? Thanks
CNKS
05-10-2003 19:53:46
 Re: PTO in reply to rock Hauler, 05-10-2003 19:25:51
I'm not familiar with MM, but it sounds like you are using the mower for heavier conditions than it was designed for -- anyway it should have a shear pin somewhere. Also on the pull type, if you turn too short, the shaft has to run at an angle and something has to give.
Rock Hauler
05-10-2003 20:00:16
 Re: Re: PTO in reply to CNKS, 05-10-2003 19:53:46
Thanks, I'll give that a try
