Farmall super C
JIM M
05-12-2003 11:30:44
can anyone tell me what type of pistons the farmall super C has without tearing it down. step or flat serial no 161135 model no FC motor no 354898-R1 thanks JIM
BobG in VA
05-12-2003 14:37:55
 Re: farmall super C in reply to JIM M, 05-12-2003 11:30:44
Take the hood off, take all the spark plugs out(make sure you lay the wires in good order to replace them), take a flashlight and look thru the holes.....You can tell by rotating the fan/crank pulley whether you have flats or F-craters or domed. That's how I found out.. BobG in VA
JIM M
05-12-2003 17:13:44
 Re: Re: farmall super C in reply to BobG in VA, 05-12-2003 14:37:55
Bob thanks you are right.
RickB.
05-12-2003 14:09:34
Do you actually think the original pistons are still in there after 50 years? No one can answer your question accurately.
JIM M
05-12-2003 17:09:58
 Re: Re: farmall super C in reply to RickB., 05-12-2003 14:09:34
Ha rick read the other feed back i got to my question .we both will learn something .Take all four spark plugs out of the motor rotate the motor by the fan and view each cylinder with a flash light that will let a person see what pistons are in the motor.Thanks for the info
