case 530 -no timing pointer
Richard Wilson
05-20-2003 10:47:45
There does not seem to be a timing pointer.The timing marks on the flywheel are there.Shop manual
shows it to be under dust shield on fly wheel housing.Is there another way to set timing?
This is a Case 530 farm tractor,4cyl. 159 engine.
Any help is greatly appreciated
Kraig
06-26-2003 15:00:12
 Re: case 530 -no timing pointer in reply to Richard Wilson, 05-20-2003 10:47:45
Gas or diesel, if it is gas take out the number one spark plug, turn the motor over in the direction of rotation and put your finger over the spark plug hole. as it builds pressure and the piston is near the top put a small screw driver in the hole and keep turning the engine slowly until u get that piston on top. Set the rotor pointing to the number one contact by twisting the distrubutor, this should get u started. If it is diesel e-mail me and I will help.
